Jump to content
DSM only displays config wizard on install
  • Please log in to reply
2 replies to this topic
#1 BRodbell
BRodbell
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 12 December 2011 - 07:34 PM
At the end of the installation of DSM free version, the configuration window is displayed to allow me to enter the initial configuration. From then on when I launch it, the task runs (in task manager), but the window never launches. How can I change the configuration without having to re-run the intallation again?
#2 Brian Stern
Brian Stern
    Advanced Member
  • Technical Support
  • PipPipPip
  • 259 posts
Posted 13 December 2011 - 08:12 PM
Dear BRodbell,
Thank you for your Forum post.
Please use the following link to download and install the fixed version of the Disk Space Monitor software:
http://www.netwrix.c...mfree_setup.msi
You can install the new version over your currently installed version.
Please let me know if the new version installs successfully and fixes this issue. I await your reply.
Sincerely,
Brian Stern
#3 BRodbell
BRodbell
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 14 December 2011 - 06:11 PM
Thanks, Brian. That worked well.
