Javascript Disabled Detected
You currently have javascript disabled. Several functions may not work. Please re-enable javascript to access full functionality.
DSM - "Failed to connect to server or shared folder '<servername>'. Access is denied."
Started by
helpdesk.rce
, Feb 09 2015 09:12 AM
6 replies to this topic
#1
helpdesk.rce
helpdesk.rce
Newbie
Members
Posted 09 February 2015 - 09:12 AM
Hi,
I get error "Failed to connect to server or shared folder 'servername'. Access is denied.". I already try to troubleshoot by follow instruction in Netwrix KB.
1. Login using account that assign for DSM, Open MMC Snap in "Services" at problem server
- Done and successful connected to remote server services
2. Map to \\servername\c$
But the error "Failed to connect to server or shared folder 'servername'. Access is denied." Still occur.
Thank you
#2
helpdesk.rce
helpdesk.rce
Newbie
Members
Posted 17 February 2015 - 09:36 AM
Admin...anybody can help me? This is URGENT
#3
dsmirnov
Posted 17 February 2015 - 01:53 PM
Hi,
Thank you
Hello,
did you try specifying another account, that is explicity added to Administrators group?
Also, can you please do the following test?
Run wbemtest
In a window that opens click Connect
Specify the following as namespace \\%servername%\root\cimv2, where %servername% is the name of the problematic server.
Click Connect
Do any errors occur dutring this?
#4
helpdesk.rce
helpdesk.rce
Newbie
Members
Posted 18 February 2015 - 01:53 AM
Hello,
Run wbemtest
Click Connect
Dsmirnov,
1. I already test use others admin account and result ok (can connect to problem server)
2. There is no error when run wbemtest and connect to problem server.
But still error "Failed to connect to server or shared folder '<servername>'. Access is denied."
#5
dsmirnov
Posted 24 February 2015 - 09:47 PM
Please provide us with the following information:
Configuration file C:\ProgramData\NetWrix\Disk Space Monitor\default.xml
The product logs. The entire content of C:\Program Files (x86)\Netwrix\Disk Space Monitor\Tracing
Example of e-mail report you get
Please zip it up and upload to www.netwrix.com/upload.
Please, reference "DSM forum" in the Subject field.
#6
helpdesk.rce
helpdesk.rce
Newbie
Members
Posted 25 February 2015 - 01:07 AM
Dsmirnov,
Already upload the files
#7
dsmirnov
Posted 25 February 2015 - 03:24 PM
Dsmirnov,
You uploaded only logs, configuration file is missing.
However in the log I found the exact error message. The product cannot connect because of the Provider load failure WMI error.
It can happen because of WMI repository corruption on the monitored erver.
You can check it with the following command:
winmgmt /verifyrepository
Also the following article might be useful.
http://blogs.technet...-wmi-class.aspx
Most likely there is an issue with Win32_LogicalDisk WMI class
