Jump to content
How to upload reports
Reporting Services upload
  • Please log in to reply
2 replies to this topic
#1 khemmerl
khemmerl
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 19 September 2018 - 08:53 PM
I've inherited a Netwrix installation and when I go into Reports > SQL Server > All SQL Server Data Changes > View, I get:
Reporting Services Error
  • The item '/Netwrix Auditor/Netwrix Auditor for SQL Server/Change Reports/All SQL Server Data Changes' cannot be found. (rsItemNotFound) Get Online Help
I found this page:
    https://www.netwrix.com/kb/1862
which says:
  1. Open the Netwrix Auditor Console using Right Click -> Run as Administrator.
  2. Select the Managed Object for the specified product with the issue
  3. Expand the Managed Object
  4. Expand the product
  5. Click on Reports
  6. On the right side click the blue "Upload" link to re-upload the reports and data source
The problem is there is no "Managed Object" icon, nor is there a SQL Server icon (which is what I'm trying to audit).  The closest is "New SQL Server Plan" but that starts a wizard to create a new monitoring plan.  Can anyone explain how to upload the reports?
Ken
#2 khemmerl
khemmerl
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 19 September 2018 - 09:13 PM
Running the Netwrix Auditor installer and selecting "Repair" has fixed the problem.  Note:  The installer prompts for a server reboot at the end so be aware if you need to do this on a live production system.
Ken
#3 techrama
techrama
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 01 April 2019 - 08:47 AM
1.Open the MySQL command line.
2.Type the path of your mysql bin directory and press Enter.
3.Paste your SQL file inside the bin folder of mysql server.
4.Create a database in MySQL.
5.Use that particular database where you want to import the SQL file.
6.Type source databasefilename.sql and Enter.
7.Your SQL file upload successfully.
