Jump to content
Install Issues
  • Please log in to reply
1 reply to this topic
#1 sottiled
sottiled
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 30 March 2015 - 04:54 PM
I am installing NetWrix Password Manager on a clean build Server 2012 R2 Std server and am hitting multiple issues.  The first error I encounter is:
Note: PkgMgr.exe has been deprecated. Please update your scripts to us DISM.exe to install, uninstall...
Operation failed with 0x8007000B
An attempt was made to load a program with incorrect format.
I click OK (only choice) and the install proceeds until I am asked for credentials and to set the website which I do.  I then get error:
Error occurred while enabling ASP extension on IIS Server.  Error code: -2146646015
Suspect the 2nd issue is related to the first as the first appears to be an ASP application configuration issue.  Any help would be greatly appreciated.
It's running on a VM so I keep returning to the initial, clean snapshot and trying different options but with no luck.
#2 sottiled
sottiled
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 01 April 2015 - 02:19 PM
Thanks, looks like .NET 4.5 wasn't working but getting 3.5 in seemed to clear the issue.  Install went successfully after that.  Thanks for the input.
