I have installed the NetWrix Privileged Account Manager and everything seems to work correctly except when I add an domain account and a domain machine where that account runs a service it does not change the service password when I check the password back in. If I add the same thing but instead of running a service with the account I run a scheduled task it seems to change the password for that part. The service account that NetWrix Privileged Account Manager runs as is a domain admin and a member of the admin group on the machine I am adding and the account I am running the service under is a local admin on that machine as well. Once I check the password back in it is successful but if I go into the services right afterwards and issue a restart of that service it fails or gets stuck stopping. Any help would be appreciated.
Thanks
Started by
Jeremy Clark
, Feb 06 2013 06:43 AM
3 replies to this topic
#1
Posted 06 February 2013 - 06:43 AM
#2
Posted 06 February 2013 - 06:48 AM
I figured it out
#3
Posted 20 March 2013 - 02:58 PM
I'm having the same issue. I when I check the ID in, I can't get a service account or a scheduled task to run successfully anymore. Before I check it in, everything works fine but once checked in, nothing works. Can you tell me what you did to fix your issue? Thanks!
#4
Posted 25 February 2014 - 07:00 PM
I'm experiencing a similar issue. For me, service account passwords appear to reset correctly, but its just the scheduled tasks that aren't working once the managed account's password gets reset. Ideas anyone?
