Jump to content
ALE - HTTP Error 500.19 - Internal Server Error
  • Please log in to reply
2 replies to this topic
#1 Scott Walker
Scott Walker
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 07 February 2013 - 04:09 PM
Hi,
Im getting the following error when trying to run ALE:
Server Error
Internet Information Services 7.5
Error Summary
The requested page cannot be accessed because the related configuration data for the page is invalid.
Detailed Error Information
Module IIS Web Core
Notification BeginRequest
Handler Not yet determined
Error Code 0x800700b7
Config Error There is a duplicate 'system.web.extensions/scripting/scriptResourceHandler' section defined
Config File \\?\C:\Program Files (x86)\NetWrix\Account Lockout Examiner\Web\web.config
Requested URL http://localhost:80/ALE/
Physical Path C:\Program Files (x86)\NetWrix\Account Lockout Examiner\Web\
Logon Method Not yet determined
Logon User Not yet determined
Config Source
13: <sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
14: <section name="scriptResourceHandler" type="System.Web.Configuration.ScriptingScriptResourceHandlerSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication"/>
15: <sectionGroup name="webServices" type="System.Web.Configuration.ScriptingWebServicesSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
Links and More Information
This error occurs when there is a problem reading the configuration file for the Web server or Web application. In some cases, the event logs may contain more information about what caused this error.
View more information »
#2 Tommy Garvin
Tommy Garvin
    Advanced Member
  • Members
  • PipPipPip
  • 92 posts
  • Gender:Male
Posted 12 February 2013 - 01:06 PM
Hi Scott Walker,
The error you have occurs because system.web.extensions sectiones are defined both in site-level and application level web.configs. This can happen with applications developed for ASP.NET 2.0 when ASP.NET 4.0 is set as default.
Please go to IIS manager, in the left pane select Applications pool, make sure that DefaultAppPool uses ASP.NET 2.0 (.NET Framework column in the central pane)
The workaround for the this is to delete or comment out all the system.web.extensions configuration section definitions and configuration section group definitions from the application-level Web.config file. It is located in the \Web subfolder in the Account Lockout Examiner installation directory.
If the issue persists, please provide us with a screenshot of the error, version of .NET installed, and your web.config file from Web folder in the Account Lockout Examiner installation directory.
Please zip your files and upload them at www.netwrix.com/upload . Please specify the following in the subject line: Forum-ALE
- Tommy
#3 mmahacek
mmahacek
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 06 November 2014 - 09:32 PM
I am getting the same error on my Win 2012 R2 server. I switched to .NET 2 and now get this error:
Detailed Error Information:
Module
IIS Web Core
Notification
BeginRequest
Handler
Not yet determined
Error Code
0x80070021
Config Error
This configuration section cannot be used at this path. This happens when the section is locked at a parent level. Locking is either by default (overrideModeDefault="Deny"), or set explicitly by a location tag with overrideMode="Deny" or the legacy allowOverride="false".
Config File
\\?\C:\Program Files (x86)\Netwrix\Account Lockout Examiner\Web\web.config
Requested URL
Physical Path
Logon Method
Not yet determined
Logon User
Not yet determined
Config Source:
139: </modules>
140: <handlers>
141: <remove name="WebServiceHandlerFactory-Integrated"/>
More Information:
