When I reply to the Account Locked Out email with the UNLOCK:passcode, the account never gets unlocked. Am I missing something with the setting option? The install was straight forward as well as setting up the passcode.
Thx
Posted 09 June 2015 - 12:43 PM
Thx
Posted 10 June 2015 - 12:59 PM
sortiz,
Most likely there are some issues accessing mailbox. Maybe cannot find the server, or authentication fails, or something else.
You can check the log file, it is \Tracing\ALEService.log in the product install directory.
Look for all messages of the REMOTE CONTROL category, will look like this:
ALEService.exe Information: 0 : [TID: 21, Time: %timestamp%] REMOTE CONTROL: FindFirstValidURL server
or
ALEService.exe Warning: 0 : [TID: 21, Time: %timestamp%] REMOTE CONTROL: System.NullReferenceException:
Posted 17 June 2015 - 07:56 PM
I did not see the errors you pointed out but this:
REMOTE CONTROL: System.Web.Services.Protocols.SoapException: The account does not have permission to impersonate the requested user.
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at ESB2010.ExchangeServiceBinding.FindFolder(FindFolderType FindFolder1)
at ALService.RemoteControl.Listeners.MSExchange.ExchSoap10MailBox.get_Folders()
at ALService.RemoteControl.Listeners.ExchangeServerListener.GetMessages(RemoteControlSettings settings)
at ALService.RemoteControl.Listeners.DefaultMessageListener`1.OnDoWork(DoWorkEventArgs e)
ALEService.exe Information: 0 : [TID: 339, Time: 6/17/2015 3:22:34 PM] REMOTE CONTROL: Listener will be restarted after 00:01:00 minutes
Posted 14 July 2015 - 06:23 PM
sortiz,
the error means the account cannot authenticate to the mailbox.
Double check its permissions, the service account must be the owner of the mailbox and have full permissions of course.
Posted 26 January 2018 - 05:09 PM
Did you ever get it to work? Would you mind sharing your fix?
Thanks-
