Jump to content
NAS Synology integration with Netwrix
NAS Synology
  • Please log in to reply
4 replies to this topic
#1 Overwrite
Overwrite
    Newbie
  • Members
  • Pip
  • 2 posts
  • Gender:Male
  • Interests:Netwrix
Posted 27 February 2018 - 04:50 PM
Hello guys,
I would like to know if it's possible to integrate a NAS Synology with Netwrix ?
Thank you.
Best regards,
Overwrite
#2 AndreyK
AndreyK
    Member
  • Members
  • PipPip
  • 14 posts
Posted 02 March 2018 - 05:39 PM
Hi,
There is no native support for Synology in Netwrix at the moment but there can be workarounds.
What type of events you'd like to collect from that device? Please clarify.
Regards,
AndreyK
#3 jorge_gandula
jorge_gandula
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 19 April 2018 - 08:25 AM
Hi,
@AndreyK: I am interested in this topic. Can you please describe possible workarounds?
I would like to track/collect events like create/modify/delete files on Synology (Synology device will be configured for integration with Active Directory)
Thanks and regards,
J.
#4 AndreyK
AndreyK
    Member
  • Members
  • PipPip
  • 14 posts
Posted 19 April 2018 - 10:35 AM
Hello Jorge,
The first workaround presumes using Netwrix API for collecting and processing events from Synology devices.
If it is possible to make the device send events to the Netwrix host in a syslog-compatible format (and I believe that Log Center can do that), it should be possible to configure parsing rules and save those events to the Netwrix database.
https://www.netwrix....tegrations.html
The second workaround is using Event Log Management if Synology device can save events on a Windows host in .evtx format.
Hope this answer helps.
AndreyK
#5 jorge_gandula
jorge_gandula
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 19 April 2018 - 02:23 PM
Hi Andrey,
it helps a lot.
Thanks for the advice, I will give it a try.
Regards,
J.
