Jump to content
disk space monitoring :
  • Please log in to reply
2 replies to this topic
#1 bob ross
bob ross
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 21 December 2013 - 05:35 AM
Hi - as this takes .net 3.5 - does that mean I cant run it on win 7 ?
I have .net 4.5 installed currently.
after I add a server it gives me the following error and appears to shutdown :
the new task has been created but may not run because of an error : Transaction support within the specified resource manager is not started or was shut down due to an error.
also this 'new task' is that created in the task scheduler or just the program.
im assuming this is not working due to my dot net ver ?.. if so how do I get it working on win 7... as dot 3.5 doesn't appear to be compatible w/ win 7. ( or is it ? )
thank-you
#2 jeffb
jeffb
    Advanced Member
  • Administrators
  • PipPipPip
  • 384 posts
  • Gender:Male
Posted 21 December 2013 - 03:22 PM
Bob,
You can install .Net Framework 3.5 but 4.5 is fine. Also the task is created in Windows Task Scheduler. This most likely is not a .Net issue anyways as doing a bit of research led me to this:
http://serverfault.c...-started-or-was
-Jeff
#3 bob ross
bob ross
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 22 December 2013 - 06:54 PM
Bob,
-Jeff
Thanks Jeff - I will try it - I just wanted to test it before placing it on a server. Will give that a try - thanks for the help !
