Jump to content
Real Time Notification - Not working?
  • Please log in to reply
9 replies to this topic
#1 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 05 July 2018 - 02:23 AM
Hi Community,
Installed this tool on my PC.
I set up my servers to monitor. I set up my mail settings.
I tick the 'Send notification in realtime' option.
I click on Verify and a successful email comes through.
I click on Generate and a successful report gets downloaded.
I clink on Apply, I type in credentials and an email comes through indicating success.
Problem is that it doesn't notify me in real time when the free disk space falls below threshold.
Apparently I should get reports every 3AM too, but those aren't coming through either.
I noticed when I press Apply, the program closes. Is the program supposed to be open or closed in order for the automated reports to come through?
Is there a service or application that is supposed to run in the background?
Thanks,
Jacky
#2 SergioS
SergioS
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 06 July 2018 - 03:13 PM
Hello Jacky,
It would be helpful to see what the tool's logs say. They are located in the installation folder (by default C:\Program Files (x86)\Netwrix\Disk Space Monitor\Tracing). Please post the logs and we'll see what's going on.
Also, "notify in real time" is an option that schedules the disk space monitor task to run every 10 mins. You may want to take a look at the history of the task to see if it simply fails to start.
Best regards,
Sergio
#3 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 09 July 2018 - 12:05 AM
Hi SergioS,
Log file attached.
Today, I turned on my PC and a notification came through.
I would like to know more about the 'notify in real time' selection.
Does it only notify me when the threshold is triggered between every 10 minute check?
Thanks,
Jacky
#4 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 09 July 2018 - 05:09 AM
In case I failed at attaching a file, log file uploaded here.
https://we.tl/0zsXGHQ6Ab
#5 SergioS
SergioS
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 10 July 2018 - 07:28 PM
Hello Jacky,
Yes, the tool is pretty simple and will notify you only when the threshold is triggered. It's not sending any scheduled status emails.
By looking through the logs I did not see anything wrong with the tool.
Best regards,
Sergio S.
#6 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 11 July 2018 - 12:59 AM
Hi Sergio,
I agree that the tool is simple. I just didn't understand how the tool was supposed to operate.
Testing
2018/07/11 10:52
These are my configured settings
I generated a report and it shows:
At 2018/07/11 11:05, I will add files in order to trigger the threshold.
#7 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 11 July 2018 - 02:32 AM
2018/07/11 11:05
Copied multiple files to consume the free space and break the threshold.
Current free space is 15.9GB.
2018/07/11 12:32
Am I supposed to have received a notification by now?
#8 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 11 July 2018 - 10:56 PM
2018/07/11 17:05
Restarted PC. I'm not experiencing any that is telling me that the disk monitoring is working.
I've checked the log and the last event was the one at 2018/07/11 10:52 where I applied the settings and generated the report.
#9 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 15 July 2018 - 10:30 PM
2018/07/16 08:25
Started PC after 2 days powered off.
I got 2 email notifications. 1 x Detailed Report, 1 x Notification Report.
I don't understand the concept of Real Time Notifications?
I only get notifications when my PC turns on after an extended period.
EDIT: I'm going to switch to the Daily Notifications and see how that behaves.
#10 jacky.yang
jacky.yang
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 24 July 2018 - 05:43 AM
2018/07/23 8:29AM
Started PC after shutdown previous night. Same as previous.
2 emails notifications. 1 x detailed report, 1 x notification report.
It doesn't seem to be generating consistent reports throughout the day.
Only has been producing reports when I first turn on the machine after a shut down the previous night.
