Jump to content
Inactive User tracker email alert
  • Please log in to reply
1 reply to this topic
#1 GAH
GAH
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 11 May 2016 - 03:38 PM
Does anyone know if the FReeware Inactive User tracker is allowed to send scheduled email reports?
I have configured this feature but am not getting any emails.
I do get email reports from the Password notifier
Regards
#2 jeffb
jeffb
    Advanced Member
  • Administrators
  • PipPipPip
  • 378 posts
  • Gender:Male
Posted 12 May 2016 - 03:41 PM
If it has SMTP settings then it has the ability to send emails.  Assuming it is running, any SMTP errors received would be in the products tracing which can be found in either the install directory or in the ProgramData folder (under the products subfolders).  This can also tell you if it is running because if there is no tracing then the EXE that runs from the Windows Scheduled task is not being kicked off.  Of course if there are no SMTP settings then it just has the ability to run Ad-Hoc reports.  I can't recall if this is the case as I don't currently have the freeware version of that module installed.
-Jeff
