Jump to content
File Server: Folder traversal tracking or wildcard usage in a filter field
  • Please log in to reply
2 replies to this topic
#1 WinskiTech711
WinskiTech711
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 27 January 2015 - 08:26 PM
I was tasked with recording how my users move through our file server (Server 2008) in an effort to see who accesses what with the hope of re-organizing said file server to make it more efficient. I thought the File Server portion of Auditor would help me out.
I have the File Server portion up and running, but I have a few questions. My task was track users through the File Server. When I'm setting object level auditing for my Windows share folder, I see the option (after getting into Advanced permissions) for "Traverse folder / execute file". From what I've seen in Auditor though, there's no way to pull up this information. For example, if only wanted to see what folders a specific user accessed, how would I do that in Auditor?
If Auditor doesn't record that information, I might be able to get it another way. I'm thinking on a report, in the "UNC path" field if I could add a wildcard character in I could filter on a specific parent folder add the wildcard character then the report would spit out a list of changes on that folder and every file and folder inside of that parent. For example, if I wanted to see list of everyone who changed a file or folder inside of my "Public" folder I could put "\\public\*" in the UNC path and get changes just related to that folder and everything inside of it. Does anyone know if this is possible?
#2 jeffb
jeffb
    Advanced Member
  • Administrators
  • PipPipPip
  • 377 posts
  • Gender:Male
Posted 27 January 2015 - 08:36 PM
Hello,
Some of the things you are talking about like SQL Reports and filtering are only available in the paid version or the trial so I assume either you have paid already or you are currently trialing the enterprise version. In which case you are welcome to create a support case on our Customer Portal or call our support line. Let me know!
-Jeff
#3 WinskiTech711
WinskiTech711
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 27 January 2015 - 10:10 PM
Jeff, thank you very much. I called support and they answered all of my questions even though I'm only using the trial version. Great first experience.
