We use a 3rd party piece of software that changes the primaryTelexNumber field of users AD accounts. This occurs numerous daily and is creating a large amount of "noise" on the daily reports being delivered.
Is there a way for this to be omitted, either from the report itself or even from being audited in the first place?
If you know the property name you can exclude it in the file omitproplist.txt which is found in the install directory using similar syntax as seen in the other properties that are omit by default in that file. You can get the property name from the attribute editor built into ADUC.
