Jump to content
Disable "Password Never Expires" option
  • Please log in to reply
2 replies to this topic
#1 dwfrey8877
  • Members
  • Pip
  • 2 posts
Posted 04 November 2015 - 10:15 PM
We are looking for a way to completely disable the option for "Password Never Expires" when resetting a password. Is there a way to do this without modifying a .asp file to remove it from the list of helpdesk options when resetting a password?
#2 dsmirnov
    Advanced Member
  • Root Admin
  • PipPipPip
  • 58 posts
  • Gender:Male
Posted 05 November 2015 - 01:43 PM
You can configure User options on the corresponding tab under Settings on the Administrative portal.
Just clear the checkbox called "Enable the 'Password never expire' user option"
#3 dwfrey8877
  • Members
  • Pip
  • 2 posts
Posted 05 November 2015 - 06:51 PM
I've done that, but that only seems to apply when a user is resetting their own password. When someone uses the Helpdesk to reset a password they still have the option for "Password Never Expires". Is there any way to remove that option from the Helpdesk?
