Jump to content
Reduce frequency of Event 17137 logging
event 17137
  • Please log in to reply
2 replies to this topic
#1 MarkDym
MarkDym
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 07 February 2018 - 04:05 PM
Hello
I have noticed that the Netwrix Password Auditor database is being closed/opened every 3 or 4 minutes. This appears in the Windows Application Log as:
Log Name:      Application
Source:        MSSQL$SQLEXPRESS
Date:          07/02/2018 14:47:41
Event ID:      17137
Task Category: Server
Level:         Information
Keywords:      Classic
User:          HTLINCS\administrator
Computer:      Janus.htlincs.local
Description:
Starting up database 'Netwrix_Auditor_EventLog'.
I have resolved this type of excessive logging in the past on a different SQL database by using SQL Management Studio to change the Auto Close option from True to False.
Is it safe to do this for the Netwrix_Auditor_EventLog database?
Thanks
Mark
#2 jeffb
jeffb
    Advanced Member
  • Administrators
  • PipPipPip
  • 378 posts
  • Gender:Male
Posted 08 February 2018 - 02:24 PM
Hello,
I don't see any issue with this.  However it should be noted that this database is for Netwrix Event Log Manager as Password Expiration Notifier does not have a database.  If you don't need ELM you could disable that product and not have to worry about this DB.
-Jeff
#3 MarkDym
MarkDym
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 09 February 2018 - 11:07 AM
Aha! Thanks - don't know why I assumed it was PEM. Thanks for pointing that out. I'll change the option and see what happens.
Cheers :)
