Jump to content
Disk space monitor - different notify amount for each server
  • Please log in to reply
1 reply to this topic
#1 cscott
cscott
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 02 March 2014 - 09:06 PM
Hi there, great product. I was wondering is it possible to set a different "Notify if free disk space falls below:" amount for each server?
#2 jeffb
jeffb
    Advanced Member
  • Administrators
  • PipPipPip
  • 380 posts
  • Gender:Male
Posted 03 March 2014 - 02:33 PM
Hello,
This is not possible in the GUI however it is technically possible. If you will notice whenever you modify settings in the GUI the following XML file gets modified accordingly (C:\ProgramData\NetWrix\Disk Space Monitor\default.xml). Also there is a scheduled task in Windows Task Scheduler called NetWrix Disk Space Monitor which has an Action that points to the default.xml profile. In theory if you were to create multiple profiles and scheduled tasks to point to them all you could accomplish this. The basic idea being that the GUI always will create a default.xml file if it doesn't exist. You then set up the GUI and then when done, close out and rename the XML file and then point a new task to it.
-Jeff
