Hi There,
Is there a simple way of changing the interval time from 10 minutes.
I'm using the app to monitor only one service, which is core to the company I work for..
Can this be reduced to an interval of say 1 minute?
I like the product, but would be really nice to have an option to set the interval myself.
I look forward to your reply.
Kind regards,
Alex
Interval Time
Started by
Simp1710
, Nov 13 2014 08:15 PM
1 reply to this topic
#1
Posted 13 November 2014 - 08:15 PM
#2
Posted 14 November 2014 - 07:18 PM
Simp 1710,
The product runs on a Windows Scheduled task. So if you go into Windows Task Scheduler there will be a task called Netwrix Services Monitor. This task by default has a trigger that repeats every 10 minutes. All you would need to do is modify the trigger for the repeat duration you want.
-Jeff
-Jeff
