PAM Freeware IIS Issue
#1
Posted 02 May 2012 - 03:36 PM
HTTP Error 500.19 - Internal Server Error
The requested page cannot be accessed because the related configuration data for the page is invalid.
Module DynamicCompressionModule
Notification SendResponse
Handler SSINC-html
Error Code 0x8007007e
Requested URL http://localhost:80/PAM/Default.html
Physical Path C:\Program Files (x86)\NetWrix\Privileged Account Manager\WebSite\Default.html
Logon Method Not yet determined
Logon User Not yet determined
Has anyone had this issue previously? If so, any fix?
#2
Posted 07 May 2012 - 12:56 PM
Please see the following MSDN article: http://blogs.msdn.co...s-in-iis-7.aspx :
For above specific error (mentioned in this example), DynamicCompressionModule module is causing the trouble. This is because of the XPress compression scheme module (suscomp.dll), which gets installed with WSUS. Since Compression schemes are defined globally and try to load in every application Pool, it will result in this error when 64bit version of suscomp.dll attempts to load in an application pool which is running in 32bit mode.
This module entry looks like:
<scheme name="xpress" doStaticCompression="false" doDynamicCompression="true"
dll="C:\Windows\system32\inetsrv\suscomp.dll" staticCompressionLevel="10"
dynamicCompressionLevel="0" />
Hence to get rid of this problem:
Remove/Disable the XPress compression scheme from the configuration using the command below:
%windir%\system32\inetsrv\appcmd.exe set config -section:system.webServer/httpCompression /-[name='xpress']
-OR-
Add an attribute of "precondition= "64bitness" for this module entry so that it loads only in 64bit application pools
- Tommy
#3
Posted 27 June 2014 - 03:38 PM
Hello KGradert13, Welcome to the NetWrix Forums!
-OR-
- Tommy
i just installed PAM to a windows 2012 R2 server and i am getting the same error. the link in the above post does not work and i do not know how to fix this issue. can anyone help??
#4
Posted 27 June 2014 - 06:31 PM
This freeware product has not been tested on IIS 8 or 8.5. You can try enabling all features available in IIS but this is untested and likely will not be tested by development unless it is removed from being freeware.
-Jeff
#5
Posted 02 July 2014 - 02:37 PM
