Is it possible to remove Netwrix branding from password expiration notification email?
I have the template like I want it but I either need to customize the top and bottom banner to my company or remove it them altogether.
Posted 05 January 2018 - 02:08 PM
Posted 05 January 2018 - 02:31 PM
This is possible to accomplish by editing a registry key on your Netwrix Server.
Open regedit and navigate to:Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Netwrix Auditor\Password Expiration Notifier
Find the "HideEmailAdditionalInfo" key and set to 1
If they key is not listed, you will need to create a DWORD with a value of "HideEmailAdditionalInfo" and set it to 1.
Hope that helps!
Michael
Posted 05 January 2018 - 08:11 PM
thanks, this worked!
