Jump to content
Unable to Install ALE Web on Windows 10
ALE Web IIS
  • Please log in to reply
8 replies to this topic
#1 jholston
jholston
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 19 February 2018 - 09:22 PM
 Currently, when trying to run ALE Web Setup to install Helpdesk Portal 4.1, I get the following error:
IIS Windows component has not been installed, or the ASP.NET, Windows Authentication and IIS 6 Metabase Compatability (required for IIS 7) features have not been enabled.
I believe I have configured IIS correctly to the best of my knowledge according to the Netwrix Account Lockout Administrator Guide. There isnt an updated section for windows 10 but I did not think it would matter.
I have attached a screenshot of my config.
Hopefully someone can tell me what I am doing wrong or lead me in the right direction. Thank You very much for your time.
#2 mpurdin
mpurdin
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 20 February 2018 - 11:27 PM
If you click on Start/Run and then type in inetmgr, do you get any results?  If so, can you post that screenshot here?
#3 jholston
jholston
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 21 February 2018 - 01:23 PM
The IIS Manager opened up.
#4 mpurdin
mpurdin
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 21 February 2018 - 09:19 PM
If you click on Change NET Framework version, make sure you are running 3.5
#5 jholston
jholston
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 23 February 2018 - 09:53 PM
The only options I have are for 4.0.30319 and for 2.0.50727.
.net 3.5 has been installed from windows components.
See Attached
#6 chipDE
chipDE
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 29 August 2018 - 08:56 AM
Can you please fix this problem? I think it is only a false detection in the Setup.
#7 server.team
server.team
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 22 January 2019 - 02:49 PM
did this get solved as this is the same issue I am getting on Windows 2019
#8 Kirill K
Kirill K
    Advanced Member
  • Administrators
  • PipPipPip
  • 103 posts
  • Gender:Male
Posted 23 January 2019 - 08:21 AM
Hi there,
I replied you at http://forum.netwrix...?showtopic=3595
Best regards,
Forum Engineer
#9 Kirill K
Kirill K
    Advanced Member
  • Administrators
  • PipPipPip
  • 103 posts
  • Gender:Male
Posted 24 January 2019 - 02:08 PM
Hi there,
During installation it is checked that the "ASP.NET" component installed, since it has "ASP.NET 3.5" name in Windows 10/Server 2019 OS, there is no match and the warning message is returned that necessary components are missing.
The Help-Desk Portal is supported on the following operating systems, please review the attached image and consider to use one of them.
Best regards,
Forum Engineer
