ALTool.exe Error: 0 : [TID: 1, Time: 3/11/2020 8:26:05 AM] System.TimeoutException: This request operation sent to net.pipe://localhost/ALService/Settings did not receive a reply within the configured timeout (00:02:00). The time allotted to this operation may have been a portion of a longer timeout. This may be because the service is still processing the operation or because the service was unable to send a reply message. Please consider increasing the operation timeout (by casting the channel/proxy to IContextChannel and setting the OperationTimeout property) and ensure that the service is able to connect to the client.
Server stack trace:
at System.ServiceModel.Dispatcher.DuplexChannelBinder.Request(Message message, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at ALTool.ALService.ISettingsManager.ResetSettings(List`1 objects)
at ALTool.Clients.SettingsClient.<>c__DisplayClass3.<ResetSettings>b__2(SettingsManagerClient x)
at ALTool.Clients.DefaultServiceClient`2.ServiceAction[TRes](Func`2 act, Boolean trace)
at ALTool.WindowSettings.ButtonOkClick(Object sender, RoutedEventArgs e)
ALTool.exe Information: 0 : [TID: 1, Time: 3/11/2020 8:27:24 AM] Tracing started. OS version: Microsoft Windows 10 Enterprise OS Architecture: 64-bit, Machine: LEEPC108, Username: INSIGHTCU\alexana, Interactive: True, CPU count: 4, CLR version: 2.0.50727.9148, UTC: -4, DLST: False, Assembly File version: 4.1.417.0
ALTool.exe Information: 0 : [TID: 1, Time: 3/11/2020 8:27:24 AM] .NET Versions are accessible : CDF N/A; 2.0.50727.4927; 3.0.30729.4926; 3.5.30729.4926; v4 N/A; v4.0 N/A
ALTool.exe Error: 0 : [TID: 1, Time: 3/11/2020 8:33:25 AM] System.TimeoutException: This request operation sent to net.pipe://localhost/ALService/ALInfo did not receive a reply within the configured timeout (00:02:00). The time allotted to this operation may have been a portion of a longer timeout. This may be because the service is still processing the operation or because the service was unable to send a reply message. Please consider increasing the operation timeout (by casting the channel/proxy to IContextChannel and setting the OperationTimeout property) and ensure that the service is able to connect to the client.
Server stack trace:
at System.ServiceModel.Dispatcher.DuplexChannelBinder.SyncDuplexRequest.WaitForReply(TimeSpan timeout)
at ALTool.ALService.IALInfo.GetAllObjects(Boolean locked, Boolean notlocked)
at ALTool.Clients.ALInfoServiceClient.<>c__DisplayClassd.<LoadAllObjects>b__c(ALInfoClient x)
at ALTool.Clients.ALInfoServiceClient.LoadAllObjects(Boolean locked, Boolean notlocked)
at ALTool.MainWindow..ctor()
